Franklin Ace-1000 Beeps (sometimes) with a Garbage Screen
Just picked up a Franklin ACE 1000 and I have an issue. The computer powers with a screen full of garbage (various random characters, many inverted, with a few random solid and checkered blocks mixed in), and will beep on power-up most of the time (every so often it's silent). Usually hitting reset will cause it to beep, and typically change the garbage on screen (fewer characters, or more spaces, lots of exclamation points).
So far I haven't done much to it. Cleaned it out. Removed something like a dozen acorns from inside. I didn't see or smell any evidence of something living in there, and some of the actors were too large to fit through the slots in the back. I can only conclude that someone did that intentionally. I just can't figure out why. I also opened the PSU to check the REFAs and tested the voltages (they seem good). Removed the two cards (a Microtek parallel printer card and a Franklin disk controller). I should note that with the disk controller installed, there is no beep at all, and the garbage on the screen consists of blocks and patterns. I got a similar result out of an Apple ROM card with Integer BASIC.
That's about it. Beyond that, I really don't know what I'm doing with this. While I do own several Apple IIs, up till this week, the oldest was a //e, which is a very different animal (even if largely compatible). I now have an Apple ][ Plus as well, but currently it's in worse shape as it neither beeps nor gives a picture. I may post about that later if replacing the 74S86 doesn't help. For now, I've been going through Sam's Troubleshooting guide (how I knew about the 74S86), but I'm not sure how much of this will translate? Does anyone know of a troubleshooting guide specifically for the Franklin? Or have some idea where I should be looking? Any help would be appreciated.
Below is a photo of the motherboard. There's a strange jumper wire that runs from the IC at B12 all the way to R62 [missing] at A14. I'm not sure if that's normal or not. Also, there are two screenshots, the first is of the initial power-up, the second is after I hit reset.
Screen Shot 2021-11-06 at 12.24.14 AM.pngScreen Shot 2021-11-06 at 12.24.43 AM.png
I'll caveat this by saying I know nothing about the Apple II clones (and not too much about the genuine "II" range either (mostly into 68k Macs)), but I recently restored a //e Enhanced which presented almost identical issues. I suspected the RAM, but after deep cleaning the 'board, replacing the RIFA in the PSU, methodically testing each RAM chip, the TTLs, custom and ROM chips in a known working //e... I found the issue - the 65C02 (CPU) had failed. Go figure. Of course, YMMV... Good luck!
Thanks! The machine booted after swapping the first chip! Then, after repeated testing, it went right back to what it was doing before. Weirdly, the first chip I swapped looked to be Apple-branded. Don't know if this is important, but all the RAM chips are ceramic cases, and the one at F6 is soldered to the board. It's literally the only IC that is (has me wondering about the sockets). I ended up swapping every chip with the first row (except the one soldered into F6 obviously) with no success.
So at this point, this has become a tale of two computers. Not making any progress with the RAM, I tried swapping chips between the Apple ][ Plus and the Franklin, trying to see if the no video/no beep would follow a damaged chip. I ended up swapping the 74S86 (B2), and transplanting (as several of the legs from the Frankin ICs snapped right off as soon as they left the sockets) the 74S175 (B1), 74LS153 (C1), 74S195 (C2), with no change in the Franklin's behavior. (Side note, I knew this thing was a clone, but I had no idea just how much of it was copy and paste.) At this point, according to the Sam's guide, IC failure is not my ][ Plus's problem. I still have to get replacements for B1, C1, and C2 anyway as I have two computers that need them, and now only enough chips for one.
I suppose I'll try swapping the RAM from the ][ Plus to the Franklin? I still don't know if that bodge wire on the Franklin board is normal or not, but it doesn't seem to be interfering with operation, so I guess I'll leave it. Also, now I know that the keyboard is nonresponsive. So progress! Still, if anyone has any ideas...
It's working now. No idea why. Still need to fix the keyboard. All of the come pads have deteriorated, so they'll need to be replaced. Does anyone know where I can find them?
I don’t have a Franklin, but probably the ram setup is similar to early A IIs.
I will try leaving one row (the first one) only and swapping around ram chips to locale the faulty ones.
Texelec make sets of pads I used to refoam my Lisa. Worked well.
Thanks for this! And sorry it took me so long to respond. I ordered them and they should be here in about a week!
Unfortunately, I have another problem. The garbage screen is back, and I still don't know why???
I've tried every socketed RAM chip on the board in an Apple ][ Plus and every chip tested good. So... not the RAM? There were several ICs with corroded legs that I replaced, but there has been no change in behavior. I'm starting to turn my attention to the sockets themselves. I had sprayed them all with contact cleaner before it came back to life, but maybe there's some oxidation or corrosion that I missed? It would make sense if the chips were corroded that the sockets would be too, but the thing is, none of the RAM is corroded, only a handful of logic ICs. I don't know. It might explain why rearranging the RAM temporarily brought the computer back to life? Any suggestions?
New problem. The power supply blew! Bad RIFA. Popped, spit smoke, no -5v on board. Sadly, I'm going to have to go over it before I can proceed further.
OK, So good news! The PSU is fixed and giving out good voltages! Also, the keyboard is working to the best of my knowledge. Bad news. The motherboard is giving me no beep and no video?
Possibly fixed! The 74LS195 at C2 was in backward and I didn't notice it. Swapped it out (as turning it around revealed that it was fried) and so far the computer has come back to life! Also., the keyboard seems to be fully functional as well!
