Floppy disk drive cleaning question.
JRL
68000
So I bought a NOS floppy disk drive cleaning disk with cleaning liquid. Problem is that the cleaning liquid bottle won't dispense liquid. > :(
Should I be able to use water instead?
the lower the percentage the higher the water content, I would recommend 99%
But in reality whatever you have should be ok, just let it dry off
If you ask nicely and don't look like you're planning to drink it, you might be able to get it from a pharmacy/drug store/chemist.
