Flashing a PB3112 SATA card
sigtau
I've got a PB3112SATA150 card coming in the mail.  I've read on here that it's possible to flash the chipset to be bootable in the Beige minitower G3 but I have no idea where to begin/what to search on how to go about doing this.
Anyone have a link/guide/pointers on how to do this?  I have a few PCI-compatible PC motherboards I can pop it into to do the deed.
Here's my method of doing it easily:
There're a few other ways if you dig around the forums, although I had various levels of success using them. The Wiebetech ROM is easy to flash but it won't work under classic Mac OS. The Seritek ROM is a bit more difficult to flash but it'll work with everything.
There is a thread for that somewhere here in the hacks section.
In short:
-You need the Sonnet/Firmtek Seritek Firmware (v5.13 should be the way to go)
-you need one of three possible flash chips the firmware works with - it checks chip IDs and refuses to work with the wrong chip (pm39lv040, mx29lv040 will work)
-you might have to move a 0ohms resistor to supply the flashrom with 3.3V instead of 5V - you should be able to trace the correct resistor when going backwards from the 3.3V regulator
-flash in an external flasher - saves you from a lot of hazzle with silflasher not liking some flash chips
