Fixing scsi drive
I got a new LC and it has the old old black 40mb conner drive. Of course it wouldn't work so i tried the trick putting tape over the black rubber bumbers. Now it spins at the beginning and hangs. Its not recognized on the performa 6116cd . Is there a better fix? Thanks
This is pretty much a symptom of an aged hard disk drive, and not much you can really do.  You may be able to get it to start working, but likely only for a short period of time.
You should look for a replacement drive if  you want to continue using your computer.  There are lots of various options from SCSI2SD to Jaz and Zip drives, to another old aged drive, to putting a SCSI3 server drive in with an adapter.
