Finally had some time to take a look at my 6100, which arrived yesterday...it's in fairly good shape, though one of the big tabs that holds the case on is broken off and it wasn't in the seller photos and I'm in the process of gluing the hard drive carrier back together. It's a pretty early one, dated March 1994. I look forward to sorting this thing out and solving the video out problem, whether through one of those adapter cables or buying 360Alaska's 266MHz Sonnet accelerator and a HPV card.
Well the LC580 is a unique machine as in its wired like a 5XXX/6XXX power PC, and the 630, etc..
the 575 and under are like the CC. Keep that in mind.
But I had a feeling the 580 wouldnt make it. a 5XX machine never does, the plastic is way too brittle. Same thing happening with the 5XXX series as well.
In order for a 5XX to survive, you almost need a box 3 to 5 times the size, and packaged properly. Even then the shipping would be cost prohibitive at that point.
Some shippers do know how to send the 5xx and 5xxx. I purchased 7 various machines of those lines off eBay in the past 1-2 years and did not have a piece of broken plastic on any of them.
You just have to keep watching. All the ones I've bought have ended up being in the 150 range with shipping. I immediately ignore the ones that want over 200.
Yeah, those are usually the ones that have been put up a hundred times because the seller is delusional. I have LC and Performa saved searches on eBay so I'm always watching for these machines, and I always recognize the ones that have been up there for months at $200 plus shipping.
I got this old Western Digital FW400 external drive on Friday for $3.50, but of course it didn't come with any cables so I can't test it. I've never seen a power connector like that before, looks like a ADB/S-Video connector. I wonder what capacity it is, and if the drive inside is even any good...
If the drive's not good, you should be able to put another IDE disk in it.
The power adapter is an annoying type but common-ish. It's probably around somewhere, like in the thrift store, but it probably wouldn't say western digital on it.
The Performa 6116CD I picked up to replace my 6100/60 works great! It even has a bigger hard drive than the one the 6100 had, and some cool software on said hard drive to boot.
