EtherWave Mac/PB Adapter and Classic Mac
OK! This gives hope!
anyone who has this file?
FENI222.sit.hqx
PowerBook Adapter Installer 2.2.2
This installer will install drivers for EtherWave and EtherMac PowerBook Adapters. It also contains Firmware (Adapter Setup 2.2.1), AppleTalk files, and Utilities (CheckNet and Ethernet Diagnostics).
The file: PowerBook Adapter Installer 2.2.2 (616K)
I have scoured the internets for you using Google and come up with nothing. Unless you can find someone here, LEM, or AppleFritter that has the driver, you are out to luck.
If you do happen to find it, please share it here so it can be preserved for anyone else that needs it in the future.
It's too bad they used FTP with Robots, if they had it inline with the webpage, being less than 1 MB, the Internet Archive would have just sucked it right up into the archive for indefinite preservation.
I did also some research and couldn't find the drivers too. Too bad!
I did some research in things which are available and found out that my installer EN Card Installer 2.3 is probably the right driver.
If you look at the proxim suppport (successors Farallon) site you can download a file called 59xv23.sit.hqx
http://proximtechnicalservice.com/support/farallon/cards/download/59xv23.sit.hqx
If you download it it is named FENI2.3.sit...so almost the same as FENI222.sit.hqx.
I have the feeling that it should work......
Also the installation goes without problems. Normally the installation disk will complain it the hardware is not on board...
So...please..please..please. If there are owners with a working EtherWave and with a driver disk....please help me to solve this mistery!
I would also love to try the file FENI222.sit.hqx. Maybe someone has downloaded it in the past?
I'm not lucky.....
I put it on a 1.4 M disk ...called the disk Farallon EN Installer 2.2.2.. But it is complaining that:
"This is not the correct "Farallon EN Installer 2.2.2" disk. What I'm I doing wrong? It also doesn't install from an external hard disk...
sorry to hear that, there must be some kind of disk check then
i'll see if i can get any luck with the installer tommrow (however i don't actually have one of these etherwave adapters)
Maybe someone here might be able to patch the check out?
You shouldn't need the setup utility, you just need to drop the PB Adapter extension in the extensions folder. That should do it (this is assuming you want to run it in Ethernet mode"
No go!
I added the PB Adapter extension in the Extension folder and rebooted. Still no extra choice in the Network control panel or MacTCP. I guess I really need to do the setup......
My latest guess is that I need to put the Installer maybe in the root of the floppy disk??
If someone else has a good idea..please let me know!
BIG SUCCESS!!!!!
IT WORKS!!!
On advice from one of our members I used Shrinkwrap to mount the disk. Then, with Extentions off, I installed the drivers with success.
Now the PB Adapter can have a own IP adres from the normal Ethernet range I use in my house. So no macIPgw....
My PowerBook will be online tonight on:
http://mac.vanegten.com
Comming week I will make some screen shots to show how it works.
Sorry that that image from my site never worked out, and now my site is also offline :/
I'm glad that you got this sorted out!
Why is this? What happened??
I hope you get it back soon (assuming you didn't take it down intentionally, of course).
c
p.s. Did you ever sell your Plus?
Yes the plus was sold :'(
also the site is down on purpose because I couldn't afford the renewals and the hosting :'( :'(
It's all good. I have backups of everything and eventually it will go up on a free host.
Tested it today on 7.1 and 7.5. Both install without any problems. I used Shrinkwrap on 7.5 and Diskcopy 6.3.3 on 7.1
Setup MacTCp as Ethernet Build-In and use an IP adress from the normal Ethernet range. I use as DNS my MacIPgw, which has a name server on board.
So in my setup the PowerBook has 192.168.62.209, the router / gateway 192.168.62.1 and my MacIPgw (nameserver) 192.168.62.10
So...yes a EtherWave adapter can work with MacTCP without any gateway. It behaves as an Ethernet card.
I'm glad that I could have tested this now!
To round it up.
I bought the EtherWave adapter in June 2013. I didn’t work. A red light was burning. When I opened it up I found out that one of the capacitors was getting much to warm. I replaced it and I had green lights all over!
When I connected it without any driver it worked like a normal hardware LocalBridge. You see the AppleTalk network, but cannot use it as an Alternative Ethernet card or switch to it in network or MacTCP control panel.
Thanks to all our community I got the drivers. Many thanks for that again. I will attach the image I used for this on this post.
The rest is simple. Just mount this disk and install the drivers on 7.1 or 7.5. Startup with Extentions Off (hold shift when booting).
You see two images how the network control panel looks and the MacTCP control panel.
This is the image for the version 2.2.2.
FarallonEtherWave.zip
