I was wondering. Is there enough power on a SCSI cable that if you used an EL Wire it'd glow? I've seen SCSI terminators that light up an LED. Would be cool if the termination wire was an EL Wire instead... glowing when you terminate a SCSI chain.
I have an el wire at home. I wonder if it'd work. Suppose I can just try it. I don't quite understand the SCSI cable layout, anyone here hazard a guess which wire I'd use? Presumably the termination wire... or whichever two wires would be used to make an LED light up.
Practically speaking, though, it sounds like a sort of crummy idea. It would probably be safer to tap your 5v more directly off, say, a SCSI enclosure's power supply and drive your blinkenlights indepenantly. A typical LED like you might find in a light-up external terminator only pulls about 20ma; that's a tenth of what an EL cable run will draw and I'd also worry a little about a cheap little inverter putting noise on the data lines if you pull from TERMPOWER.
El Wire power cables already exist. I guess the actual SCSI cable itself would be problematic. I was thinking maybe El Wire would be similar to a regular LED, but I suppose not.
I'm sure that power cable has the power supply for the EL wire embedded in the plug housing.
Really, if you want to make a SCSI cable like that there's nothing stopping you, assuming you can find or make a 20-something conductor cable with a clear outer insulation you can thread the EL wire into. I'm just skeptical that driving the inverter with termpower is a great idea. There are plenty of other places you can tap 5v or 12v in a chain of SCSI enclosures.
