Hi,
I purchased off eBay a Duo Dock II, which is labelled as such on the underside of the case and says "Duo Dock" on the front white top lid.
Went to slide in my Duo 280c ... and it doesn't fit
So I'm assuming I've a Duo Dock II with the original Duo Dock lid (later models I believe used a slightly higher lid to fit a slightly thicker colour Duo) ... which is really disappointing
Can anyone please shed some light on this - how can I identify if I've the original lid, and are there any modifications I can perform to make it fit? Otherwise, this thing is useless.
Cheers
JB
Cheers
JB
