Duo 210 compatibility
Maybe, instead of posting new topics EVERY TIME you have a question, make a big topic with ALL the questions you have.
By posting new topics, you are CLOGGING the 68k PowerBook forum.
OK folks -
The first 100 posts of this forum's index contain nine posts by Challenger 1983.  That doesn't seem excessive, let alone CLOGGING.
Let's have a look at the rule in question:
No cross/multiple posting…
The forum is small enough that you don't need to post multiple copies of one topic. We will merge or remove multiple topics without notice.
I think in recent memory we removed or merged one thread by C1983 that was a near-duplicate.
Challenger 1983: what I'm going to suggest is one thread per model or per machine.  If you can keep (for instance) all your Duo 210 related posts in one thread, you'll have the advantage of people familiar with that machine being able to have a look over all the issues you're having with it in one go.
The SD to SCSI question seems okay on its own, as the same thing applies to a number of different machines and other people might be interested in the same solution.
I'm also going to suggest that you use the forum search function (or Google with site:68kmla.org) a little more to check for existing answers.
Meanwhile folks, if you think there is an important issue with a particular post, thread, comment, or user, please consult the 68kMLA Forum Rules page first, and then, if necessary, bring it to the attention of the mod team by PM or by using the Report link at the bottom of each comment.
Thankyou.
