Hello! I just obtained a Performa 6300CD! Everything seems to work including the floppy, HD and CD-ROM. The computer came to me with no system installed on the HD so I used a Legacy Disk Image stored on my BlueSCSI to install a version of OS 8 on it. Not bad! However, I read that it will also run OS 9 which isn’t on my legacy restore disk. Im not sure what is the best way to get OS 9 on this thing. Should I find an install disk image in Macintosh garden and burn it on to a CD? Or could I put the same image on the bluescsi? If I did this would I need to save it as an HDA? I would prefer to install on to the build in HD rather than using my bluescsi as the HD. Any advice is appreciated.
