Hi,
I'm about to setup my 1400C for dual-booting systems 7.5.3 and 8.1. I've read that 7.5.3 will only support 4GB max partition whereas 8.1 is good for up to 2TB.
So, I recently got hold of a nice 1400C that already has a 8GB CF card in place of its spinning HD (7.5.3 and 8.1 installed on 2 x 4GB partitions). Right now I have my upgrade 128GB CF card waiting in the cardbus slot and I'm unsure how best to proceed:
Should I...
a) Format two partitions (One 4GB standard + one 124GB HFS extended) then copy the files from each system partition over?, 124GB for system 8.1 obviously.
Or:
b) Format three partitions, 2 x 4GB + a single 128GB partition for shared storage accessed by both systems.
(Will this actually work? Can 7.5.3 and 8.1 read from HFS standard and HFS extended, interchangeably?)
Or:
c) Format for four partitions, 2 x 4GB (one standard, 1 extended), then 2 x 60GB partitions (again, one standard storage for 7.5 3 and one extended storage for 8.1).
Thanks!
Should I...
Or:
Or:
Thanks!
