I come. In the possession of a DP 800mhz G4 QS. It has the gigabit Ethernet and I have plugged two different LAN cables into it coming from my 8 port switch and the switch shows no activity at all and the Mac says the cable is unplugged. Is it normal for these to go bad? Is there something I can try to fix it? This is a fresh install of Tiger 10.4 too. Was the same on the previously installed software
