Hi all, just settling in for a Lemmings session on my old faithful Q650 and a loud pop followed by the mains tripping occurred.
Looking inside the PSU it seems like it could be the capacitor at C13, the board is quite greasy looking here and there. On the back you can se the trace has been blown off. Also note the scorch mark on the case below that area.
Question is, is a re-cap and repair likely to fix this or should I go for a ATX swap - which I don't really fancy doing tbh
