Dim and Yellow display PB 520c
The lcd Seems dim, yellow tint and washed out. I just want to make sure it is the backlight before I start to look for a new one to replace mine.The caps don't seem to be leaking.IMG_20250420_171932~2.jpg
Is there a yellow tinge when the PowerBook is turned off? It could be more the polariser film/glue degrading. If not, it's a prime candidate for an LCD strip backlight.
No yellow when off. What is the pros and cons of lcd and ccfl back lighting.
I had a similar issue with a G4 iBook, but changing the CCFL tube didn't fix the problem as I had hoped. Perhaps the actual problem was the LCD's laminations were degrading. The very expensive, circa 2007 Leica M8 digital camera's LCD had a similar issue, which has been dubbed "coffee staining".
