Did I kill my iMac G4 1.25 GHz PowerPC? :(
Preview pic (after clean and before OS reinstall):
I bought this iMac from someone else. I opened the iMac to replace the battery on the mobo and clean it. I also added ram into the extra slot. I put it back together and it was working well (see pic). Since I bought it from someone else, I decided to reinstall the OS with 10.3 discs that I bought new, since that was the OS on it already, I thought it would be fine.
Some stuff went a little wonky during the clean:
  • The heatsink bar that goes over the processor was stuck to the heatsink on the top of the machine and wound up bending. Didn't realize it at first and I tried to put the bottom and top back together with it bent.
  • This caused two things:
    • One RAM clip broke off (it still seats fine and RAM seems undamaged). Before I started OS reinstall, both RAM were being read (see screen).
    • Small scratch on one of these round whole on the mobo -- not sure they have a function? (Not my pic, I think it's the one under the metal heatsink bar).
Anyway, I fixed the heatsink bar and put it back together. It was working well, I even saw extra RAM reading on screen (see pic).
At this point, I started the new OS X install. New shiny discs. Disc 1 went well. When on Disc 2, there was a kernal error 00000001. I should have taken a pic and I regret not doing so. A bunch of text read on the left side of the screen, screen was still on but frozen. Keyboard input did not seem to work. So I did a hard reboot since it was locked up after I waited for a while.
Upon hard reboot is when the real trouble started:
  • Screen is now black, no LED backlight, no picture.
  • Keyboard inputs do not seem to work.
  • Fans are running, there is a start up noise.
  • Disc seems to be spinning from what I can tell.
I have tried (multiple times):
  • PRAM reset
  • PMU button
  • Removing extra RAM with PRAM reset & PMU button
  • Running only with extra RAM without mobo RAM with PRAM reset & PMU button
Future steps:
  • I'd like to get the disc out but I can't open the tray since keyboard input does not work. Is there a manual way to do this?
  • I ordered a mini-VGA to VGA cable to see if an external display will work.
  • If I can get the disc out, I'm wondering if I should insert an earlier OS disc (which one?) Not sure if that would fix the screen issue but maybe would prevent it from bricking again. Any experience here appreciated.
If you have any advice on what to do here in the meanwhile or something I haven't thought of please let me know. I'm really unhappy that such an awesome machine that I just spent quite a bit of money on is now non-functional. Thanks for your time if you do put some thought into this.
