Desktop pattern question
Gil
68000
I noticed that whenever using Desktop Pictures in OS 8.1, the picture doesn't overlay the pattern until the desktop is loaded. Is it possible to save an image as a desktop pattern so it loads when the boot process takes place? This would also be useful in System 7.x where you can't use desktop pictures out-of-the-box.
The only solution I can think of is to use Backdrop, which places an image on the screen as soon as its INIT is loaded, but I don't know if it works under 8.1. (Backdrop seems to be mostly a System 6 utility and has been discussed extensively on this board). I've never tried it with a newer version of the system but it could be worth a shot. However, if it doesn't work, don't be surprised (mostly due to the age of the program).
