Dead 6100
To follow up it seems that the replacement has bad onboard ram. :(
Luckily The Hackery once again came to the rescue and are supplying me with replacement DRAM chips for me to solder in.
I wonder if you can increase the capacity of the on board RAM by using larger DRAM packages...
Maybe? That seems plausible, although there may be a reason it can't. Supposedly it can be upgraded as far as 520mb (8mb + 256mb + 256mb) using ram sticks. I'd speculate you might have to increment the memory on the board by multiples of two the though given how the simms must be installed in matched pairs.
