Daystar Universal PowerCache P33 in SE/30
I start to wonder why no one noticed this before.
Like nobody ever had the actual cache on the universal PowerCache working in an SE/30 before I guess (at least without the official adapter)
Just a random dude wanting that last 3-4 MIPS out of a 68030 machine along with someone that actually knows what's going on! :-)
But yeah I think this is pretty big news for llsi Adaptor/TwinSpark/ProtoCache users.  I mean there have been these types of builds described on Gamba's site that would have the same problem.  Not everyday you discover something new 20 some years odd on, all thanks to @Bolle .
Don't have a pic, but, cheers!!
was referring to the PowerCache/030 vs. the SE/30 Socketed upgrade.   I may have misinterpreted, but I took this, " on the socketed PowerCache which uses the same GAL set. " to mean that you had determined that the PowerCache030 with the EuroDIN connector uses the same GAL set as the SE/30 upgrades which plug into the 68000 socket.
Were you perhaps comparing the IIsi/SE/30 adapter(s) to the IIcx adapter in that phrase?   Sorry for the misunderstanding.
Going to verify both, the SE/30 vs. IIsi adapter and P33 vs. SE/30 PowerCache thanks to @Udo.Keller who sent me some things to play with :D
Be careful @Bolle, that does not look like a P33 card - no label in lower left corner. Yours looks like the regular non-universal powercache card (seen here), which I believe only works in the IIci. Not positive, but there might even be an electrical risk of plugging one of those + adapters into non-IIci machines.
For reference, here's what my P33 looks like.
EDIT: Looks like I'm wrong, see @omidimo's response below.
Interesting. I don't understand what changed to make the P33/P34 ones 'universal' then, if prior ones still worked with adapters. The TwinSpark states it can only work with P33 cards, but then again the TwinSpark is most likely a clone of DiiMo's IIsi adapter.
The P33 added support for a slew of later 68K machines:
Looking at this, the design was modernized with fewer chips but DayStar altered the location of the support spacer hole:
The spacer optimization is clear on this image:
I have both card versions, but I never tried either in my SE/30s... got the Diimo and a couple of Turbo 040s.  }:)
I know that the one in the picture is the older "IIci only" non universal version, but thanks for the heads up.
It still seems to work fine in the SE/30 though as far as I can tell.
Sounds cool guys.  For those of us for whom the details discussed in this thread are a little over our head, a summary of what has been discovered to date, and what exactly it does would be helpful.
Same speed on both of them.
As far as I can tell the schematics are nearly identical for the P33 and the SE/30 PowerCache so the GAL sets should really be the same as well.
Summary: if you are using a TwinSpark with a Universal PowerCache, you are not getting full speed compared to the Socketed PowerCache.  This is because the cache is not enabled even if it is turned on in the control panel.  To enable the enabling of the cache, add a jumper between C11 and C13 on the cache slot of the TwinSpark.
This may also apply to the IIsi adaptor and DiimoCache adaptor but we don’t know for sure.
It does. It also applies to the adapters I built so far. You will have to jumper the /CENABLE pin (C13 on the cache slot connector) to ground, otherwise the cache won’t get activated.
So neither the GAL nor the 74ACT86 do anything on that SE/30 adapter if you use it in the SE/30...
The GAL code is the same as on the Daystar IIsi only adapter.
The input signals present at the GAL are the same as on the IIsi adapter, only a few output pins are routed to different places on the SE/30 connector.
Only signals that are important are on pins 17, 18 and 19.
/CFLUSH stays high all the time. Pin 18 (connected to C20 on the SE/30 cache connector) is high all the time as well.
/CENABLE stays low all the time.
The 74*86 outputs a high signal all the time as well because the two inputs 1 and 2 are receiving the same signal. CPUCLK and C16M are tied together on the SE/30 PDS slot.
It will only output something on the IIsi where CPUCLK is 20MHz and C16M is - guess what :tongue: - 16MHz. The signal coming out of there is then routed to /CFLUSH on the IIsi cache connector.
This means for a P33 -> SE/30 only adapter there isn't any GAL (or even any chip) needed at all. A 7486 to boost the clock signal if you use two PDS cards would be a good thing to do though as this constellation might cause problems otherwise.
If you wanted you could even wire up your P33 to the SE/30 PDS using a lot of jumper wires. No magic going on here at all.
Wow.  That's amazing.   Great work, Bolle!  Thank  you.
Is it possible to buy a PDS flat cable for the DIN-connector?
There are .1" pitch ribbon cables.   I don't think I've ever seen a premade cable with a Euro-DIN connector on the end.  I'm also pretty sure that the easily available ribbon cables don't go past 40 or 50 conductors.   I looked into trying to bring the SE/30 CPU socket up with ribbon or flat flex cables some years ago.
