Converting NewtonOS debugger images for use with Einstein?
How do you convert NewtonOS debug images for use with Einstein? I have read that some people have run Einstein with a debugger image.
i made a rom image from my MP 2100 its 8+mb in size to use for einstein, i had to use a beta version of it to run on my G3 and had to set the date back so i could use it. the one you can find now wont work on my G3 or G4.
other than that i dont know how to convert the newton OS debug images to use in Einstein. i would just find someone that has a rom image
I don't recall doing any sort of conversion..
Which debugger image did you use? Einstein just said that the image needed to be 8MB with all the images that I tried, and when I cut them down to 8MB, Einstein appeared to boot, but pressing the power button did nothing.
I used the "Cirrus NoDebug" image, which seemed to work fine. I'll have to check out the latest builds of Einstein to be able to tell for sure.
