Hi everybody,
My Colour Classic has some stange issues. When I plug it in and the AC switch is on, some crackling noises come from the inside. The noises are not very loud, but clearly noticeable. Otherwise, it runs fine since I recapped the LB. Furthermore, after letting it run for some time, I heard a sound like that of escaping steam (or rather like the ‘explosion‘ of a capacitor during desoldering).
But when I removed the analog board, there was no obvious damage on the caps… The only suspicious thing is one of the transformers, which possibly has melted sealant. I conclude that this sealant gets hot and escaping air from bubbles inside make the second noise I described above.
Does anybody know what the problem might be and how I cold solve it?
Is there a modern (or NOS) replacement transformer available?
Robin
Robin
