I have had for a few years a 20" ColorSync monitor from c. 1997 in which the included ADB ports do not work. On a ColorSync, a failed ADB port is worse than it sounds, because it is not possible to use the appropriate software utilities to adjust brightness, etc., without a functional ADB port. The monitor, alas, needs some fine tuning after all these years (though usable in the right light, it has become very dark), fine tuning that I am unable to perform because of the failed ADB. The brightness button on the front of the monitor, which kicks into action when the software extensions are disabled, has been used to push the brightness up as far as it can go, which isn't very far. There are no pots around the back or under the plastics that allow further adjustment to be done manually on a ColorSync; such adjustment has to be done by software.
To fill in some of the details, what happens when the proper software for the monitor is installed (AppleVision/ ColorSync) is that I get an AppleVision error message on startup telling me that I do not have an ADB Cable plugged in (when I do). This happens in system software from 7.x right through to 9.x. I am instructed to check the cable connection and reboot. Oddly enough, power on works through the ADB port (since the keyboard is connected to the monitor's internal ADB and the monitor cable includes an ADB plug which goes to the machine). The only remedy for this error message is to disable the AppleVision software via the Extensions Manager, though the error message can also be by-passed and the machine used — since this is not a system crash.
I have replaced the ADB board in the bottom of the machine with one scavenged from a 20" AppleVision monitor (the same animal before the rebranding to ColorSync). No joy. Symptoms are identical.
There is nothing about this in the Service Manual. Is there anything obvious that I could try? Fuses? Laying on of hands? Fasting and prayer? These were absolutely top of the line monitors back in their day, and I would very much like to get my 20" ColorSync working properly.
