Any help understanding/troubleshooting a 6100 problem I have?
Hello all!
Yesterday I got a new (old of course, so, new-old) 6100/60 I bought, which I connected to a monitor I have. The machine had an extra video card so I used the standard Mac video port that was there first, and the machine booted and worked fine. Used it for a couple of hours, powered off, returned today, and now there is no video (boot chime, sounds like it's - like yesterday).
After getting no signal, I also tried the "default" port (a "fatter" connection that seems to be the default for this machine) but same problem (no signal).
When I first started it today, I forgot to power on the display, but then after restarting etc. it still doesn't work (changed monitors and cables, and the monitors and cables I tested works fine today with, for example, my 7300.
Any tips on things I could try, and if there's a chance that it's not broken but that something else happened?
I have no idea about the history of this machine - bought it from someone who has never used it and bought it some time bak thinking it was a PC.
Appreciate any input on things to try, and apologise for the newbness here!
It’s the flat or missing PRAM battery that causes no-video on these machines if I’m not mistaken. As a workaround, you can try resetting the machine quickly after power up.
Ah, thank you very much! That would be the [Command (⌘) + Option + P + R] approach?
Seems the batteries are cheap and easily available still, so if that's the problem that would be great!
I think you power it on, then quickly off and on again.
Yeah, the 6100 is definitely one of those machines that can’t be run without a PRAM battery and I know it specifically affects video output. The other is the LC475, there may be others.
