Bill of Materials:
Color Classic Case - runs fan when switched on without mobo
Color Classic Mobo - original to the machine, horrible recap from a rookie that looked stunningly like me 8 years ago.
575 Mobo - cleaned but not recapped as of yet
The Classic will switch on to fans with no motherboard in the case, so we have hope for the analog board (I would assume).
The horribly recapped mobo was my first recap attempt and has tons of busted traces and I used the wrong kind of flux, etc, and the Classic won't go to fans if I have it in the case. I've tried the in/out trick holding down the power switch with it and got nowhere.
I'm just looking to get this thing off the ground and reading all of the various Mystic guides can get confusing. And most seem to be starting from a working base Classic, so my case is somewhat unique.
Thus, can I recap the 575 mobo, make the resistor mods (http://www.applefritter.com/powercolorclassic/stuartbell/compendm) and stick it in the Classic and get anywhere with it? Or, do I have to start with a working Classic to make the necessary changes for the ?
Will a working stock 575 board work in the case at any particular system revision?
(Yes, I plan to recap analog board and fix the stock Classic mobo eventually)
