You cant measure ohms while the machine is running! thats how you blow shit up.
That thermistor should get warm. So that means current is flowing through the degaussing coil. Possibly. When you first plug power in while everything is cold and flip the switch you should hear that coil go DOOIINNKKK and out. itll be fast.
With the machine on, and picture on screen. Unplug the degaussing coil and see if the colors jump or shift on the screen to a complete 180 of where they are now.
If it does not, and the thermistor is getting really hot then you may have a shorted coil.
Worst case scenario the aperture grille could have gotten knocked loose or shifted during shipping and thats permanent and cannot be fixed.
Also, when the computer is off, as long as the mains is connected and the switch is on, that circuit is constantly getting power and it will stay on and stay hot IF there is no cut-out relay. I will have to check and see if there is one or not. I cannot remember.
