color classic grey screen
falen6
Hi folks.
Got a color classic recently - powered it on and it chimed and gave the display of the flashing disk icon
the logic board was in a terrible state - amazed it even chimed.
recapped the board with tants and gave the board a much needed clean
put it back in and powered it on - chimed and display
took out the logic board and re inserted it a few times and the hard drive was working , booted all the way to desktop
powered it on later on and all i get is a grey screen ..BUT the machine boots to the desktop and plays some sound (same sound it played when it got to the desktop when the display worked)
so i have a CC thats working but the display is grey
i thought it would be the memory chips , but if that was the case then the machine would not continue with the boot
have not opened up the machine to even look at the analog board
am i just unlucky that after the recap initally worked , the analog board decided to act up !!
have read that the 256k vram is the 2 chips next to the vram expansion slot - ive checked and reflowed them - still the same - i guess this is why the machine is booting regardless of the video problem
took the back cover off to have a look - machine is very clean inside - checked the big slot connector for the logic board and it appears solid and clean
i have replaced every cap one by one from the recap just in case one was bad , but still the same
machine is responding to keyboard commands to shut down , to restart
its just a video issue
volume and brightness controls on the front all working
the machine came with no ram or vram expansion simms
have gone over every solder connection with powerful magnafying glass......... cant see whats the problem is
the board is spotless now , front and back
