Hi Folks....
Can anyone tell me the CFM and the dBA of the *original* Color Classic fan?
The original fan is 80 mm X 80 mm by 25 mm. I believe the fan housing
can take at least 80 mm X 80 mm X 32 mm fan.
While I have my Color Classic apart, I thought I would install a fan
that is quieter, and if I am lucky, moves more air. But I can not even
began to hunt for fans unless I know what the dBA and CFM of the
stock fan.
I strongly suspect that in the last 20 years, fans can move more air
and make less noise. And they may be able to do it while drawing less
current.
I have looked high and low, but i am unable to find the CFM and DBA of
the original fan.
I have seen a replacement fan on a Color Classic FAQ. It is a 80 mm X
80 mm X 25mm fan called a PANAFLO FBA08A12L. It is 12V, .1a, 1900
RPM, 21 dBA, and 24 CFM But because I have no idea what the original
fan is, I do not know if this fan is noiser or moves more air around
or not.
Anyone have this information? Anyone want to make an intelligent guess?
Thanks so much.
jack
stock fan.
current.
the original fan.
or not.
Thanks so much.
jack
