That's because it is. Right through until the late 90's the Apple market was FLOODED with OEM crap that was nearly identical. There might be a different color plastic or there might be an extra badge but otherwise a lot of the time it was all the same hardware (HDD enclosures with Conner or Quantum drives or pretty much selling the Sony SMO-E501 in a different enclosure.Looks similar to this.-link-
Let me know how it works out Uniserver. Was thinking of getting one for my Plus before I have a go at the internal SCSI mod.Wow I just bought one. Thanks for the link
Macs do not send power down the SCSI bus and the spec. does not support it. It needs an external power supply.The Clipper one doesn't need any external power adapter
I wouldn't even bother with terminating the drive. When attached to a compact mac you have less than three inches of actual cable length between the controller and the drive.Do you think it is self-terminating, or it would need a terminator stuck to it?
