Cleaning rusty ports/connections
Any recommendations on how up clean up old rusty ports i believe my se/30 had spent several years in a garage so the ports are some what rusty (be it surface rust) is it just a wire brush and care or is there some miracle way to clean them up that you guys have found? ;)
I'd go some fine steel wool/sandpaper, wet sand, then once dried spray some WD40 on the ports to prevent further rust
the wire wheels of the dremel are pretty good.
10pcs-Removing-Rust-Dust-3mm-Brass-Wire-Wheel-Brush-Shank-Suitable-For-Rotary-Dremel-Drill-Tool.jpg.0afe8424c52f842b99c8984903c623d5.jpg
3pcs-Steel-Wire-Wheel-font-b-dremel-b-font-wire-Brush-burr-abrasive-head-font-b.jpg.7cce08798c4882ffc2703b303a123901.jpg
I havent got a dremel but my suster has so defo seems let effort way ;) i'll see what i can do this weekend before i box it up and send to you ;)
