Posted to the Mac OS 9 mailing list.
Classilla 9.2.1 is released.
This is primarily a bug fix release for the browser; there are no specific
layout or JavaScript changes, so if a site did not work with 9.2 it will
probably still not work with 9.2.1, and there are relatively few new features
this go-around.
That said, there is a big one, and that is Script-B-Gone. While I could never
confirm these myself, I got enough complaints about the whitelist getting
zapped, or not keeping up, or missing entries, that I hatched a scheme for a
more reliable way of tracking sites (and at the same time improve the rather
primitive interface for this older version of NoScript, specific for the
limited XUL controls in this version of Classilla).
Because this solution is intended to mitigate the problem with corrupted
whitelists, YOUR WHITE LIST IS NOT COPIED TO THE NEW FORMAT: YOU START FROM
SCRATCH WHEN YOU UPDATE TO 9.2.1. You might want to note the important sites
you need JavaScript for so you can transfer them over by hand. You can switch
back and forth from 9.2 to 9.2.1 (I don't recommend this, but you can), but
any changes you make in 9.2 are not seen by 9.2.1.
When you visit a site, click on the S as usual. Instead of NoScript, however,
Script-B-Gone appears and offers to add frames from the same domain (the
default), the URL site only, or all frames, or let you visit the manual
options window so you can add and delete sites as usual. For most sites,
enabling JavaScript is two clicks: one on the S, one on OK. The page will
automatically reload with JS on. That's it.
SBG keeps your whitelist in two places: the active whitelist used by the
browser to block scripts, and a shadow whitelist that SBG and NoScript
modify, and which SBG keeps in sync. SBG will adjust the active whitelist
and log errors if the active list does not match the shadow list, which
will help if there are deeper errors afoot.
If you activate SBG on a permanently whitelisted page like about:, it won't
let you delete it, and if you activate SBG on a page you have already
enabled scripts on, it will tell you and let you go to the options window
if you still want.
There are various other sundry small new features and bug fixes, such as
better tab management (open in background tab; Cmd-Shift-T to open the
last tab closed), more user agents, smoother socket timeouts, better
support for Unicode and updated libpng; see the releases page for all
the issues that have been fixed or mitigated. This version also adds the
MRJ Plugin -- MAKE SURE YOU MERGE YOUR CURRENT PLUGINS FOLDER WITH THIS ONE
if you have any special plugins you are using. The MRJ Plugin requires
MRJ 2.2.4 or higher (2.2.6 is recommended). You only need it if you need
to run Java applets, which is still discouraged.
With this release, 9.2.1 is now localization-ready: all the strings are
now frozen and will remain frozen through 9.3.1. If you want to work on
localizing Classilla for your home language (Etienne?), look at
http://www-archive.mozilla.org/projects/l10n/mlp_howto.html
If this seems doable to you, I want to sign up people for this project.
There is already a Japanese locale and I will integrate that into this
release; Mathias W is working on German, and I particularly would like
Spanish.
9.2.2 will mostly just be language packs except for any key regressions,
which I will fix in that release -- it will have no new features. I am
internally forking the codebase into the 9.3 branch so I can work on it
in parallel while the translators do their thing. I have not yet decided
if the packs will be separate or integrated into 9.2.2.
9.3.0 will be a lot of work, as it will involve hand-rewriting layout and
DOM. I don't expect to have this done for several months, but I am
committed to doing it.
Enjoy.
http://www.classilla.org/releases/
