Classic II Analog Board / no output
bibilit
68030
I am trying to fix a Classic II Analog Board, the primary side is ok and the fuse also, but i have no output on the secondary side (0 volt)
Removing and replacing capacitors didn't solve anything, probably a faulty component, but don't know where to look next.
Not fixed this unit yet, but had another one to repair, blowing fuses all the time.
My first bet was that the bridge rectifier was bad, and at first check - and + where shorted, but on removal all was ok.
Turned my attention to surrounding components, in the end The Mosfet on QP2 was shorted (IRFBC40).... a swap, some new caps on the Logic and Analog board and i have a nice working unit
Already been talked about here, so this Mosfet has a tendency to go bad.
Ok thanks is this the CNY17G-3 ?
For my information, is this component acting as a switch ?
Also, do you know the difference between the CNY17-3 and the G variant ? (as the first can be found easily)
Thanks again.
No luck here.
I saved one board yesterday, but replacing the Optocoupler in the others didn't solved the issue.
Any idea where to look next ?
