Hi All
First time post with an odd (?) question.
I recently pulled a Centris 650 I've had for years out of storage. In itself nothing major...I bought it used off of Ebay in the 2001ish time frame and would periodically pull it out essentially to play Pathways Into Darkness.
The SCSI 230meg drive still works but periodically has issues starting, so after doing a bunch of reading, ordered up a SCSI2SD V5.1 card for it yesterday.
My question is...is it possible to copy the entire hard drive including operating system over to the flash drive? I have zero system or software disks for this machine. Sure, I'm aware that the operating system is downloadable but I'm not sure how I would get it from a newer PC to this mac (no CD drive)
I'm just figuring out the best way to take a stab at this problem...I understand a clean install would probably be preferable, but I'm actually trying to avoid that since I would have to source everything again.
Thanks!
Thanks!
