Can I rename my hard drives? (7.6 on a Color Classic)
mraroid
Hi...
I am running 7.6 on my color classic.  I have four partitions to my hard drive.  They are currently named:
Untitled
Untitled2
Untitled3
Untitled4
I am booting off of Untitled4.
I would like to re name my hard drives.  But I can't fugue out how to do this after the fact.  Do I need a utility to do this, or can I do it with 7.6?
Thanks in advance
mraroid
Just select your HD (it's now highlighted), hit the enter key, rename it any way you like and the hit enter again to confirm.
Done.
Select the Hard drive, then File > get info (or Ctrl i) that will open a new window.
Your icon can be managed here.
Thanks for the good feedback bibilit.  I selected my drive, went to file, then get info. That part works.  I suspect I need to have additionl icons in my OS to choose from?  It seems that the only icon I can see is the one that is being used.  I can't figure out how to select other icons..... Maybe I need to down load some?
mraroid
If I remember correctly, you have to copy an appropriately sized image to the Clipboard, and then paste it into the icon area in the Info window.
