Though I recently did this on a MacBook Pro with FireWire, this can be (and has been) done on a G3 and G4 iBooks & PowerBooks. It also works on Desktop Macs with FireWire.
Situation: A friend and Mac Repair client, a lady in her 90s, is going blind (Macular degeneration), so I set up a MacBook with a 48in LCD screen for her to see the text, icons and windows better. She can and she's happy with the set up. Thing is she gets relatives who come in and screw up the settings on her machine and I have to go there and set them straight. Even after talking to her relatives about setting it up the setting again so she can read the screen, What can I say, they're uncaring idiots. So she got them a MacBook Pro for them to hack with so they can leave her system alone.
She got a MacBook Pro (I think it's an '09) from a Flea Market for $200. It had problems. Bent case, CD ROM does not boot or load CDs, and a Yosemite Upgrade gone bad - Apple icon, grey process bar, slight nudge on the process bar, reboot, repeat.
I have another friend with a similar MacBook Pro which she lent out for the cause.
At this point it becomes simple - get a firewire cable, turn on the broken MacBook Pro in FireWire Mode, connect to other with FireWire cable. Format the target drive with Disk Tools and use a program like Clone Carbon Copy to clone the working hard drive to the non-working hard drive, and then wait...
If the cloning process went without complaints or problems, the problem system will be fixed as an evil clone of the host system. The problem here is reseting user accounts and deleting applications and personal files until you get a bare system.
The question is, can this cloning process be done on USB or Network?
