The brittle plastics in my PM 8100 have irritated me enough to contemplate building my own case.
The machine will have a 400Mhz G3 Sonnet Crescendo, 2 NuBus cards, the HPD card and 2x U320 300GB drives. It's replacing the MDD whose PSU recently died on me.
As a second hobby I have been learning woodwork these past few years and I am leaning towards a nice hardwood case. Or Lego (I have a lot of it).
Two considerations come to mind:
1. RF-Shielding (at least I think that it is RF-shielding) — the sheets of metal inside the plastic case. Would aluminium do? I was thinking about using the thick sheets of oven liner. The sheets of metal inside the case are thicker and are surely made of iron. The compact macs have only a thin layer of metal sprayed on the cases but they also have an even lower power requirement than the PM 8100.
2. Heatflow — I want the insides to stay cool and fans are an easy solution. If I use fans, then there will have to be holes in the metal shielding. It doesn't seem to be a problem for newer computers and they have a much higher energy requirement than the 8100/80. Fans would also be a necessity if I use a case material than burns or warps.
3. Is there anything else that I should be thinking about?
Does anybody have any advice or good links they can point me towards?
Thanks
Thanks
