Beta's New Unit (7100/80 AV)
sorry if this maybe is a little semi-offtopic but betac does the label on your rom simm spell out that its 'dos ready' or not so much?
just wondering
As far as I can tell, it's just the normal ROM. It's the SAMSUNG KMM264512G-12 APPLE341-0757.
You should replace the caps anyway - these machines are old and those capacitors are reaching or beyond their end of life now. Even if they don't *look* like they are leaking, they will be or will start soon.
I recapped mine yesterday. It's a lot of caps but not too bad really. All 47uf 16v except for one 100uf 6v.
Yeah it’ll be done, eventually - have the caps on hand. One of those jobs that needs a fair bit of time put aside to do.
no problem betac, been curious about basically a '7100 dos ready' label on an untested unwanted rom simm. good luck with your nice 7100 setup btw
No 7100s were sold as DOS compatible machines and none of Apple's own aftermarket DOS compatibility cards targeted it. Although I believe that some of the DOS compatibility hardware is documented after-the-fact to work. (the 6100 DOS card in particular, once you work out how to make it physically fit.)
And, among Macs that were sold as DOS compatible and/or have affordances (e.g. 7200/120 DOS compatible or any 8500 or 5400 with a GIMO port), there weren't special ROMs to accommodate the card.
It's possible someone pulled the ROM simm out of, say, a 7200/x DOS compat and then just decided it was a DOS compatible ROM, which isn't strictly true or sensical, sine the DOS card on the 7200 and 4400/7220 was just a PCI card that was preinstall/configured.
