I've got an LC II motherboard which Brett B. kindly sent me. It needed a good cleaning and recap, and now it seems to work. I connected the PCD-50B SCSI card reader that I use with my Quadra 605, and although the LED flashes shortly after power on, it won't boot.
It occurred to me that the SCSI drivers installed on a drive might work fine for certain m68k machines, but not others. I'd try some different ones, but I don't want to screw up the working Quadra, plus I don't have a floppy drive for the LC II.
Can anyone recommend a good way to make a bootable disk using the Quadra that will definitely work on the LC II? Or, if not via the Quadra, perhaps from Basilisk II or Mini vMac?
