My apologies if this has been discussed before, but I searched and couldn't find anything. I have a blue MacEffects case and an internal BlueSCSI V2, and it's working well, but I'm looking for a way to mount it in the case, preferably in such a way that the SD card is accessible. I found some mounts for the BlueSCSI V1 that attach to the PDS slot, but I don't think they will work for the V2. I've also considered mounting it in the hard drive bracket and cutting a slot for the SD card in one of the case lines above the floppy drive, but I'd rather not make that kind of modification. I tried using an SD card extension cable, but it was causing I/O errors.
I don't have any 3D printing experience or access to a printer, but I'd certainly be willing to pay for a bracket if someone makes one that would work. A bracket that would hold it in the position I'm holding it in the photo would work perfectly, I would think.
