Bad Smell from Duo 230
kb3wmh
I own a PowerBook Duo 230, in decent shape. However, when I turn it on, it starts smelling strongly of fish. It has gotten a lot better, and seems to be working fine. What is wrong? Is it major?
the duo only has a few caps, but they are mostly concentrated around the DC jack area, and they are fairly large, and will do some serious damage when they leak.
Yup, I recently recapped two PowerBook 230 Duos which both of them had major capacitor leakage. One of them sadly decided to quit working shortly afterwards, I believe that it was probably because of capacitor leakage.
You can quickly check for the leakage by simply lifting the keyboard. If the small SMD cap on the left side is leaking, then you know that the others are on their way.
Below I provided a quick diagram of affected capacitors. One of them is already removed.
There are 4 T8 (or T7) Torx Screws at the bottoms of the case.
Here's Apple's technical notes on taking one apart. This applies to all the Duo's since they use the same case.
http://tim.id.au/laptops/apple/powerbook/powerbook_200_series.pdf
To replace the caps, you need to remove the logic board from the case, the area is too small to work with the logic board inside the case.
And TechKnight - the Apple Certified 50 pound Sledge Hammer is for repairing Worthless Windows PCs.  }:)
