I’d imagine it’d be tough, what’s your use case for HFS+ under 7.1.2? Maximum partition size is only 2GB under that OS if I remember right.If there is any chance you guys can bring this to 7.1.2 68k, I'd be very interested in that. It essentially acts like 7.5.0, is that is any useful information.
Are system files region specific?@Phipli, try this little updater I made. It is specific for 7.6.1, and an unmolested System file, but it does make the process easier. I could probably make the same for 8.0, 7.5.5, etc.
That's a good question, I am not sure. I know Finders likely are. The worst scenario is we can try it and see, but I have nothing but US-bases systems.Are system files region specific?
I have british 7.6.1 installed on my 7.6.1, I'll check if the system version says "B1" like the finder does. Give me a mo.That's a good question, I am not sure. I know Finders likely are. The worst scenario is we can try it and see, but I have nothing but US-bases systems.
The Text Encoding Converter needs to be in the Extensions folder. Is this extension supported under system 7.1.2?If there is any chance you guys can bring this to 7.1.2 68k, I'd be very interested in that. It essentially acts like 7.5.0, is that is any useful information.
Can you send a resedit file with the resources needed in it to me? I'll make a more aggressive patcher that doesn't care what it is working on.Ok, so let's say that is a patcher for the US-specific 7.6.1![]()
Not who you replied to, but for me the coolest thing about HFS+ on earlier systems would be the ability to swap Zip disks between the old computer and a modern Mac with zero issues.I’d imagine it’d be tough, what’s your use case for HFS+ under 7.1.2? Maximum partition size is only 2GB under that OS if I remember right.
Why not just format your Zips as Mac OS Standard? Because the smaller block size that Mac OS Extended format offers really only helps for partitions larger than around 1-2GB.Not who you replied to, but for me the coolest thing about HFS+ on earlier systems would be the ability to swap Zip disks between the old computer and a modern Mac with zero issues.
It should. From what I know, the only limitation is that you can't boot from an HFS+ formatted disk on a 68k Mac, but you can read write to them just fine under 8.1.btw, should 68k 8.1 work natively with HFS+? And what are the size limits there? I've looked online and some things I've seen say you need third-party software to enable it, and that only works for 68040. I'm running a patched version of 8.1 on my 68030, but it doesn't seem to read HFS+ disks. My software could just be borked, though.
HFS+ works natively on modern macOS. I have played a bit with macFUSE for HFS but I forget how well that's working currently.Why not just format your Zips as Mac OS Standard? Because the smaller block size that Mac OS Extended format offers really only helps for partitions larger than around 1-2GB.
The dream would be to have a HFS system extension.
(Stuffit 5 or MacZip or bin or hqx)
Haha, when you said 'modern Mac' I thought you were exchanging them with a G3 or somehting. I guess I don't really associate any of my truly modern Macs as coexisting with Zip disks at all. But of course HFS support is no longer there, at least not as far as write support?HFS+ works natively on modern macOS. I have played a bit with macFUSE for HFS but I forget how well that's working currently.
It's not that big of an issue for me since it's usually quicker & more convenient to share files over AFP.
Hey, USB is USB! They work totally fine with modern systems.Haha, when you said 'modern Mac' I thought you were exchanging them with a G3 or somehting. I guess I don't really associate any of my truly modern Macs as coexisting with Zip disks at all. But of course HFS support is no longer there, at least not as far as write support?
fuseHFS is basically this: https://thejoelpatrol.github.io/fusehfs/The dream would be to have a HFS system extension.
I meant for System 7!fuseHFS is basically this: https://thejoelpatrol.github.io/fusehfs/
Quick question for you on the subject of Zip-100 drives and disks. How do you find their reliability? Because I’ve been using some disks that I’ve had since 1998 in a SCSI drive I got off eBay, and I’m finding that those disks are randomly corrupting themselves or becoming unreadable. Do you think the media might be worn out?Hey, USB is USB! They work totally fine with modern systems.
HFS became read-only starting with Snow Leopard, and support was removed entirely in macOS 11 (Big Sur).
