Asante MacCon IIsi SE/30, link light does not come on, but its on at the switch
K Trueno
Hi I have recently acquired (another, I don't have a problem I promise) SE/30 with an Asante MacCon, but when I plug it into the switch the light on the card does not come on.  It does come on though at the router end.
I have an existing SE/30 with a MacCon as well, and that machine does show a link light on both ends (same cable).  The only difference between the two is that are the connectors available:  The working one has the "Thick" and the RJ45 with a little switch, and the non-working one has the "Thick", RJ45, and BNC connectors.
Any quick thoughts?  I found a manual online and I didn't see anything obvious....
Asante Troubleshooter detects the card and passes the tests (minus the loopback and ping-pong one).
Thanks!
Success!  After more experimentation, it turns out the ribbon cable to the daughter card was flipped backwards.  So remember: white dot to white dot!
Don't know if it just never worked for the previous owner, or maybe it worked on the BNC / Thick connection the way it is, but there you go.  :?:
I had that backwards as well because one of my ribbons doesn’t have a white dot.
It doesn’t seem to hurt anything because I seem to remember I did run it quite some time that way doing troubleshooting before I noticed it was backwards.
Gotta look at the pinouts again and see what gets connected when you flip the connector around.
Wow! you're lucky that didn't fry anything!
c
Yeah, was confusing considering the link light on the hub/switch side was lighting up.  Supposedly that lights up with RX wires are working.
Yeah weird.  Which daughterboard do you have?  I have one with Thick and RJ45 (and a little slide switch), and the one that didn't work when flipped had Thick, Thin, and RJ45.
