Asante Maccon for se
I recently bought an Asante Maccon for se card and I can’t find the drivers for it, if anyone knows the software for this card can you comment so I can download the software
i Think this is the bin file I downloaded for my SE/30 maccon I think it also includes drivers for other versions as well.?maybe?
I recommend reading the readme file it suggested disabling my extensions for installation by holding shift while booting and also after installing I had to shut the computer off and back on instead of just restarting for it to work I THINK. It also comes with a testing utility that should show if it's working or not.
This one should work
