AppleTalk freezes up the system when I select Connect Via E
joeq
PowerPC 7100/66
Mac OS 7.5.5
MS UAM client installed on the 7100.
Connected to a 10/100 Windows ethernet network via a brand new MacSense Nubus RJ45 ethernet card in slot 3 .
Connected via 3Com 10/100 hub to a MS Windows Server 2003 R2 via MS UAM Volume.
TCP/IP Control Panel is okay set to Connect Via Ethernet - slot 3.
The link light is ON on the hub and on the ethernet card.
But when I open the AppleTalk Control Panel and change Connect Via from Printer Port to Ethernet slot 3 the little clock icon (wait) comes up and them the system freezes up.
I can set AppleTalk to connect via Printer Port, Modem Port and Ethernet Built-In without hanging up the system but pointing it to the card freezes it up.
Any ideas/suggestions will be greatly appreciated.
Thank you.
