The very top one on the H board, is the one I meant.
How did you fix the convergence issue?
H-Stat and V-Stat. Bottom two left pots.
After putting it all back together. My wheels started spinning in my head so of course I had to crack it open again and do a thorough adjustment based on the service manual. I downloaded the Display Service Utility as well. But first turned off all the lights in the room and set the cutoff to just when it goes black woth full contrast level. I set all of the voltages on the neck board for R G and B to 140v (they were at 160) then adjusted the colors by turning down each pot as needed. Basically had to turn red down.
It looks perfect to me based on my 1990’s memories. It’s very crisp for a CRT. Much better than the ST and Amiga. The apple trinitron monitors were always excellent and flicker free.
The only bummer was the top left corner of the bezel cracked during shipping but since that happened and the display was all whack the guy gave me a full refund on it. So at least I got it for free
