Hey Guys,
I have a color classic that has worked great though the years. Tried to turn it on this week and got nothing... I guess the caps finally went.
Opened it up and had a little leakage, cleaned up with Isopropyl and ordered some caps from console5.
Caps arrive and I replaced them but it still doesn't power on
I started reading all the previous posts here and started checking voltages and traces.
What I found out was, the system WILL power up when the board is removed. As soon as I plug in the board the system immediately shuts off.
I checked the Analog Board Voltage and have a good 5v and 11.95v.
After messing around I was able to get the board to go in and the system stayed on, but i only got a black screen with horizontal lines. After I took the board back out and inspected it I found the Ti 9307XN Chip in the upper right corner by the 2 100 and 47 caps was very HOT!!!
Checked the traces around it and could not find anything off. Maybe this is the problem ?
I am hoping you guys can help
