I made the mistake of dropping the Zip Driver into the Extensions folder on my A/UX partition and now I can't boot my A/UX system. Holding down the shift key doesn't disable extensions under A/UX unfortunately. I have been looking for some way to just boot to a command line interface or SOMETHING but I haven't found any info so far. If I absolutely have to I will pull the drive and find a Linux machine to put a SCSI card in I guess.
