Try checking, Mouser, Allied Electronics, Jameco, Digikey, SparkFun, or BG Micro. You may have to spend some time looking through their catalog but they should have the parts in stock.
Also try eBay. I have found there is often a good selection of electronic components there.
In case the 475 does make the startup chime, detects the disk, but shows a black screen, a lack of VRAM is likely the cause (no VRAM onboard). The machine could be set up as a server. You might check for AppleTalk connectivity.
