I am trying to get Belkin CardBus Firewire adapter (F5u512-MAC) working in my Wallstreet. Problem is I only have a FW400 hard drive that needs bus power. From the manual.
- Use the included 4-pin to 6-pin cable, or a 6-pin to 6-pin cable, to connect your favorite FireWire devices to your PowerBook.NOTE: The PowerBook CardBus slot does not provide sufficient power to operate most bus-powered FireWire devices. To solve this problem, the dual 6-pin FireWire adapter provides an auxiliary power jack for use with an AC/DC power adapter. Choose a power adapter from 8 volts to 30 volts DC with a power rating of at least 4 watts.
