I plan on getting a pair of these IDE Disk On Module drives . . .
. . . to run in a RAID config atop a TEMPOtri flopped over 180 degrees in this position . . .
. . . parallel to the the card in a very low profile installation.
I've reworked 50pin (SCSI) IDC cable connections, but am uncomfortable with the notion of removing/repositioning an Ultra ATA cable connector. Whatcha think? I cannot imagine that crosstalk should be an issue a 1"-1.25" jumper cable?
The drives are small, but plenty large enough capacity for OS9, my apps and current use files. Mass storage will be on the slow as IDE connection, probably on a larger IDE DOM . . .
. . . whose wider form factor won't work given the tightly spaced ATA-133 connectors of the TEMPOtrio as seen below:
Sounds like a plan to me, hoping it'll work out.
