i have had some issues with 800 k drives recently, and wanted to know if somebody has figured out how to troubleshout those.
Apart from the usual cleaning, lubricating process, i came across the following issues:
Floppy carrier stuck in upper or mid position: found the eject motor wasn't working properly not allowing the carrier to go down to the bottom position.
Eject motor working all the time, so trying to eject a floppy which is not present : found to be related with the drive circuit board (swapping board solved the problem)
The last issue i am trying to solve is related with a drive unable to boot from a 800 k disk, but able to boot from a 400 k one.
I think this is related with the upper head not working properly (i have the happy mac, then the disk is ejected) but i wanted to know if i am in the right direction.
