These are hacks, basically, which so far as I understand replace the software for operating the card under Windows with software for the Mac; you need only Google the key words to see if anything is available for your card. If it's a Voodoo 3, there certainly is.How would I go about "flashing" such a card?
EEERRRRR! Wrong. Many times if a non compatible ROM is used you can still try again. Sure, sometimes it can bugger a card permanently but not all that often.- any mistakes or incompatibilities will render the card virtually 100% dead.
But completely hosing a card is not as common as you say and most of the time you just have to flash back the PC ROM and either just use it in a PC or sell it(after testing of course). Don't be afraid to buy an expensive card, just make sure success has been had with a similar one first and don't mess with the ROM too much.This is one of the situations where you'd really want to utilize Google to its fullest extent. This here page may give you a hint as to which cards would work best. You should also spend as little money as possible on cards to be flashed (except the Voodoo 3000/4000), because if the card gets hosed, you're almost completely out of luck.
I'm curious about performance...I found my 6400 and 6500 to be dog slow when compared to my PCI Macs, even with 32MB Rage Pro video cards. The MacBench scores are very similar, but when playing games, the 6500, even with a G3 upgrade, was noticeably slower.The G3 plugged into the ZIF socket. It worked well - though I think it was the slowest G3 upgrade offered for any Mac. I think I paid just over $200 (new) for it. The G3 L2 upgrades were faster.
Yes, you take a PC video card and replace the software in the ROM with software designed for a Mac.Hi, sorry to get off topic here, but what does the term "flashed" mean? I have a Voodoo card for Windows 95/98, so "flashed" means to make it work on a Mac? Just curious...
IIRC, both Voodoo 1/2 doesn't have any flash ROM on the card so there is nothing you can "reflash".Yes, you take a PC video card and replace the software in the ROM with software designed for a Mac.
